question matrix
question matrix
hai all
hwo to get the solution of the d , from the equation (k-w^2*m)*Phi
6 REPLIES 6
Re: question matrix
This does not make sense.
The variable 'd' is not in the equation you provide, so you cannot solve for it.
Note that 'find' can only be used in a 'solve block', and a solve block cannot be used in a program.
Where is the worksheet?
What exactly are you trying to achieve?
Re: question matrix
Hi
(k-w^2*m)*Phi
Can be expressed as k*Phi=w^2*m*Phi
You can resolve w^2=genvals(k,m).  So w is simply the element by element square root of genvals(k.m).
You can resolve the modes as modes=genvecs(k,m).
Terry
Re: question matrix
thanks for your help
kindly how to get the values of phi (eign values ) like as shown in figure below
Re: question matrix
You can resolve phi as phi=genvecs(k,m).  Each column of phi is a mode shapes.
Terry
Re: question matrix
Just type in what terry had already written a few times. There is no more to it!
Here is an example with the values you provided in a file you attached in another post:
Re: question matrix
THANKS FOR HELPING ME
IT IS WORKING NOW
THANKS
