random selection
payman
random selection
How can I randomly select an element of a matrix ?
1 ACCEPTED SOLUTION
Fred_Kohlhepp
23-Emerald I
(To:payman)
There is a function that returns a random number between ceertain limits. You colud use that and the ceil and floor functions to make it an integer, then use that as an index to the matrix.
5 REPLIES 5
Fred_Kohlhepp
23-Emerald I
(To:payman)
payman
(To:Fred_Kohlhepp)
Thank you. It works.
24-Ruby V
(To:payman)
You create two integer random numbers within the valid ranges, one for row and the second for the column index.
payman
(To:Werner_E)
what is the role of ORIGIN here?
24-Ruby V
(To:payman)
Just wanted to get sure that what I post works, whatever you have ORIGIN set to.
Default value for ORIGIN is zero which is perfectly OK and I IMHO there is no reason to change that, but some people like it to be set to one.
