return value from the intersection of a particular row and column in a table
Otilia
6-Contributor
I have the attached mathcad with the inputs: "a", "b" and "Table". "a" should be looking in the first row of "Table" to find a match, vector "b" should be looking in the first column of "Table" to find a match for each value of the vector. The final result should return the result from the intersection of the column and line previously identified to get the result from "Table".
Thank you,
Otilia
24-Ruby V
(To:Otilia)
Here's one way to do it. Another way might be using 2-dimensional interpolation
24-Ruby V
(To:Otilia)
Otilia
6-Contributor
(To:Werner_E)
Thank you Werner_E. Problem solved with your help.
