run a worksheet multiple times
jmit
1-Newbie
Hi folks,
My problem is that I had written a fairly complex, well documented worksheet that needed to be run through with different sets of values (call another worksheet as a component with in & out available as per other components)
http://collab.mathsoft.com/~Mathcad2000/read?104132,11e#104132
From M13 onwards, this seems not working at all!
Rewriting the worksheet to functionalize would be expensive timewise (redesign and validation) and would lose the effective link between documentation and equations.
Any help would be very much appreciated to run a worksheet multiple times (run in batch) with the latest Mathcad versions.
thx
/JM
1 ACCEPTED SOLUTION
RichardJ
(To:jmit)
See the worksheets I posted in this thread:
http://communities.ptc.com/message/164310#164310
I pointed you to these before. The ones in the thread above have improved error handling, and definitely work in MC15.
1 REPLY 1
RichardJ
(To:jmit)
