s n1
sweetnsour-disa
s n1
what is the scientific notaion?
>notaion?
Scientific notation is a way of expressing large numbers as a single integer digit followed by a decimal fraction all multiplied by a power of 10.
This is particularly useful when you don't need to see all the digits, but do need to know the overall magnitude of the number.
so rather than having:
31415926535897932384626433832795028841971693993751058209749445923078164062862090
you can write:
3.141593*1079
which conveys how big the number really is, and eliminates the extra digits that are usually not that interesting.
TTFN,
Eden
so what would this be (4x10 twoexponet)+(2x10 with a negative 3 exponet)=(6x10 with a negative 3 exponet) +(9 x 10 with a negative 4 exponet ) when you do find the answer which i`m pretty sure you can can you explain how you got this to me?
>this to me?
(4x10 with twoexponet) = 4*100= 400
+(2x10 with a negative 3 exponet)=+2*0.001=+0.002
=(6x10 with a negative 3 exponet)=-6*0.001=-0.006
I'm assuming this is a minus?
+(9 x 10 with a negative 4 exponet)=+9*0.0001=+0.0009
Now you just need to do the arithmetic
TTFN,
Eden
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
