shearforce & Bending moment
Dear all,
Need to create SF&BM overhanging beam
Prakash
10 REPLIES 10
Done.
Tell me this isn't homework.
Fred Kohlhepp
fkohlhepp@sikorsky.com
sorry since i am new user i need some guidance
However pl.repost the file it doesnot open
Prakash
What version of Mathcad are you using?
Fred Kohlhepp
Sorry yesterday it doesn`t open today i got the file.I am using Mathcad 13.During program to create graph i got struck up here is my attachment file.
Prakash
Prakash,
You will need to consider the shear force between the reatcions R1 & R2
Tt*x+R1*(x-L1) if x>L1^x<=L2
The reaction R2 should point down
TOK
Not quite.
Fred Kohlhepp
Another solution attached.
Regards, Ian.
1.8MB?????? For a file that seems to be running .18MB, based on the various versions previously posted. Even with broadband, that's a lot of bytes. I heartily recommend posting in MC11 (MCD) format. If that is not possible (and while there are a number of constructs that won't actually work in MC11, I've found very little that cannot be represented in MC11) at least use the XMCDZ (compressed) format.
� � � � Tom Gutman
The file is large because it is a performs a general beam element analysis (static and dynamic). Saving it in MCD format reduces the size a little.
Ian
Dear Ian
Sorry to late reply,great theoretical knowledge file is very much useful.
prakash
