solve partial differential equation
Gravel
         I am trying to solve the Kynch sedimentation process. For that, I need some help solving PDE with certain initial and boundary conditions. The objective is to get volume fraction (ϕ) in terms of height (z) and time (t). I am not really sure on how to go about doing this. It would be helpful if someone could take a look at it.
Thanks.
17 REPLIES 17
Re: solve partial differential equation
You appear to be using phi as a variable and as a function at the same time.
That is begging for trouble. You have to clear this up before you can begin to solve.
       I have followed the equations given in the paper. Kindly check the attachments.
To my opinion the paper uses inconsistent formulation.
At one time f is a function of just phi: "f(phi)".
At another point it is a function of two variables: "f(0,t)".
Mathcad, nor Prime will be able to work with that.
P.S
In your usage of Prime, with the derivative, you can leave the 'order' of the derivative blank if it's just 1 (It's only needed for second and higher order derivatives). That 'll help with readability.
           Since df(ϕ)/dϕ=V, can I just put V*dϕ/dz instead for the second part of the equation. Will that help? Other than that, I am not really sure on how to proceed.
Regards
I think that would help.
Now go and look up the information on 'PDEsolve' in het Prime help and apply it to your system.
Don't hesitate to come back here (with an attached Prime sheet) if you run into trouble.
{I don't have full Prime, 'cause I never wanted to pay for it; hence I'm limited to 'Express', which doesn't do PDEsolve. But I can view your files with no problem.}
PDESolve is part of real Mathcad (that is version 15 and below) for a long time, but as far as I know its not implemented in Prime.
In Prime concerning PDEs we are restricted to the use of the command line solvers.
"numol" for hyperbolic and parabolic PDEs and "multigrid"/"relax" for elliptic ones.
Highlighted
I thought I'd better try is symbolically...:
So we have an expression for the function phi.
Now from here you should be able to solve the two remaining constants a[0 & a[1 and subsequently find out if this function describes the behaviour you're looking for.
Luc.
Below are my attempts to find a particular solution, using MAthcad 15, to the equation, after having defined the boundary condition for ϕ:
Hi LucMeekes,
        Sorry for not being able to reply a little sooner. I am a little confused by how you got square of d/dz ϕ(z,t,V,a) in the pde. Shouldn't it just be d/dz ϕ(z,t,V,a) as per the original equation. Kindly clarify. I think I follow the rest.
Also, my guess is your soln is in mathcad 15 and not prime. Any ideas on how to transfer it into prime 4.
Regards
