sort matrix
SOLVED
Garnet
sort matrix
For a given matrix, I want to sort the first column in descending order WITH the corresponded component on the second column. I can't use the "sort" function since it changes the order of one column's elements only.
Could you please help me with this issue?
Thank you.
Tags (2)
Re: sort matrix
You should be using the csort(M,c) function, where you can sort matrix M on the values of column c.
Re: sort matrix
Re: sort matrix
Thank you.
