summation program
SOLVED
Amethyst
summation program
Could anyone help me with writing a program to generalize the attached calculation?
Tags (2)
Re: summation program
How about the attached?
I have added a value to d to ensure the function works.
Please upload the worksheet. I am sure you will be able to iterate through vector d.
Here is the worksheet.
Thank you Mike.
You are welcome.
If you wish you could make the first element of d zero and simplify your program ,see attached.
