symbolic solution problem
Highlighted
When trying to solve a set of four equations symbolically, when multiplying the inverse of the square matrix with the r.h.s. column matrix, the result seems to be a square matrix - instead of the expected 4x1 column matrix. (It seems that the elements in any given row are identical). The only way to view the result was to chose a pair of numerical subscripts!
Any comments please?
Dr P.I. Somlo FIEEE
Highlighted
It would be helpful if you attached an example of what you are asking about.
Highlighted
OK. Attached is my example.
Dr P.I. Somlo FIEEE
Highlighted
One subscript works fine for me, so I'm puzzled about what was wrong for you...
