transduction problem
hi,
a new prob�s comin� along....
please look attachment
thanx!
6 REPLIES 6
How does the following look?
Comments, new code, highlighted in green.
- Guy
May be so:
Valery Ochkov
http://twt.mpei.ac.ru/ochkov
thank u both!
trying that in a few hours.
ok, back again.
i took your attempt, mr. beadie, but it shows the need of a scalar. how can i fix that?
2nd. note:
it seems to be the syntax of the if-line.
when i erase it the error disapears....
On 10/14/2003 5:35:32 AM, use_Less wrote:
>ok, back again.
>that?
Without your whole sheet, I can't help you. It 'looks' right to me, but there isn't much I can do without a working version of your functions. It looks like it's just a syntax error of some kind, where some quantity that I thought was a scalar is actually being returned as a vector.
Of greater importance: is that the way you want the calculation to run? In particular, what should happen if there is ever a situation where erg_WRG_8[0] is less than or equal to t_raum, but erg_WRG_7[0] is not?
- Guy
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
