undefined variable issue of reference file
Aquamarine
Hi
MathCAD 15, I use references a lot with success but yesterday I met some bug for the first time.
My file became big and I decided to split it into two parts - processing and postprocessing.
I created a new postprocessing file and insert processing file as a reference at the beginning of it.
I post-process (output) variables of processing file and meet several variables which are not defined.
I checked them at the end of processing file - they are defined.
Has anybody had the same problem with references?
14 REPLIES 14
Re: undefined variable issue of reference file
yes,I have a few global vars in processing file
Can you post the files?
 Unfortunately, I can`t (: I can try to simplify them (delete some parts that outside of undefined variable) but what it gives me?
Highlighted
Just a guess (in the dark): Do you use global variable and/or function definitions?
Are they in any way connected to the undefined ones that Mathcad is complaining about?
What if you put them as ordinary definitions in the postprocess sheet, just above where you call the preprocess sheet... (Or do you use a top sheet that first calls the preprocess, then the postprocess)?
Thanks, Luk, I`ll try to change something with my global vars to check your idea, but only tomorrow.
Hi Luk
I`ve just checked your idea on a very simple test file. Everything works well. So, there is another reason for my issue (:.
Thank you in any case.
Why do you use global vars?
I do not know one sheet where we cannot do someone without its?
I can work without them but Im not sure that they are the problem.
