undefined variable issue of reference file
Re: undefined variable issue of reference file
@ifomenko wrote:
I can work without them but Im not sure that they are the problem.
If can - do it! And see - do you have the problem or not!
One more!
Insert in the Mathcad sheet not a reference but the second sheet itself (in collapsed area). Ans check errors!
As I already wrote, everything is OK in case of one whole file.
May be you have variables with same names in both sheets?
 have you fulfilled the following rules?
furthermore there must be no redefinition of functions, variables and constants in each worksheet.
Create daily copies of the main worksheet and possibly of the other files as well.
