to all
i wnat to use the root() optin to solve a "simple" 2nd order equation. The 1st pass works fine but I now would like to set it up so that root() give me a set of x values for a set of given parameters. Please see attahce dmcad sheet
the equaqtion is as follwos
a(A,B,t)x^2 + b(A,B,t)x + c = 0
I can solve it if I set values for say A and t
Regards
JXB
Turn the call of root into a function with arguments A and t and use that function vectorized. This should do what you are asking for:
Thanks. Much appreciated. Learnt something today!
