vlookup from a table
ptc-4260912
1-Newbie
when i look up a value from a table the answer always has parentheses.is there something in Mathcad other than vlookup where i can lookup values but w/p parentheses. please see attached mathcadsheet. The user pick a beam size, then i would like to be able to read its root beams from column 1 and 2. Also i would like to be able to look up other values as well w/o parentheses. Thank you all!
1 ACCEPTED SOLUTION
Hello!
Please see the attachment.
12 REPLIES 12
Hello!
Thank you so much Vladimir!
did you add the 0 by "[ "? could you explain to what does the step you did do?
vllookup is returning a matrix, even though it is only one element, that's what the () indicated, so by using [0, you are selecting the first element in the matrix, which is a number.
SAM FARES wrote:
Thank you so much Vladimir!...
You're welcome.
SAM FARES wrote:
...did you add the 0 by "[ "?...
Yes .
SAM FARES wrote:
... could you explain to what does the step you did do?
Please see the correct explanation from Wayne at the top.
MikeArmstrong
(To:VladimirN)
There is an issue with Vladimir's way. What happens when there are two matches?????
Using the [0, the function will only return the first match.
Mike
Mike,
Something wrong with this worksheet. At me Mathcad 15 M010 was closed with an error. Could you check it?
MikeArmstrong
(To:VladimirN)
Please try the attached. I was only indicating that the [0 trick will not work when more than 1 match is found.
Mike
The same result:
Try to download this file ("Mathcad lookup_MC15_Mike.xmcd.zip") and then open it.
MikeArmstrong
(To:VladimirN)
I have just downloaded and opened with no issues.
Mike
This is strange . However, yesterday I corrected the initial worksheet from another computer.
MikeArmstrong
(To:VladimirN)
That is strange. See image from worksheet below.
As I said, not much in it only indicating the problem if more than one match is found.
Mike
