write a text file
Relayman
write a text file
In MCAD 15 I have a sheet that has lots of math variables whose names start with the letter d. e.g. dVAR1, dVAR2.
Is it possible to write code in MCAD that would read through the entire sheet and write those variables and their value to a text file?
e.g. dVAR1 = 4.50
dVAR2 = 11.75
best regards,
russ
MikeArmstrong
(To:Relayman)
Yes.
e.g. dVAR1 = 4.50
dVAR2 = 11.75
Do you want to keep them in exactly that format?
What do you intend to do with file after? Because this will dictate the method used.
Mike
Mike,
The plan is to write them to a text file and keep their exact variable name but trim off that leading d. This would be something that was "executed" manually after I'm satisfied with what i've done in the sheet. The end product being a text file with all those variables and their values and comments.
I would want it to look like the following so text is mixed in with numeric values.
e.g.
[BLOCK A]
QUAL=FAVORABLE
[1]
VAR1,"4.50"
VAR2,"11.79"
[2]
VAR3,"114.85"
VAR4,"UNFAVORABLE"
VAR5,"400"
thanks,
russ
MikeArmstrong
(To:Relayman)
Have a look at my example below. With a little bit of formatting that can be done.
Mike
MikeArmstrong
(To:Relayman)
Have a look at the attached worksheet, I was trying to use the WRITEPRN function but the text file was displaying the result as a matrix.
I have used a scripted component curiosity of Richards 'Extra Components' worksheet. Hit F9 over the icon to get the function to execute. Also change the path to your desired location.
Mike
