zero not zero
zero not zero
In MathCAD, I used an expressions like:
if (cos(angle), expression 1, expression 2)
Meaning: if the cosine of the angle is not zero (TRUE), then evaluate expression 1, else expression 2.
or: if (1,2,3) yields 2
if (0,2,3) yields 3
I assumed that cos(PI/2) = 0.
BUT: it appears that 0 is not exactly 0. Even though I fill in n*(PI/2), and cos(angle) yields 0, the IF statement does not yield proper results.
Only if I round of cos(angle) at approx. 12-13 decimals, do I get proper results with the IF statement.
also, sign(cos(angle)) never yields 0, only 1 or -1. It should yield 0 at angle=PI/2.....
Did I miss something? Is there a better way then to "force" the results to 0 by rounding them off?
Any wizards here to help me out?
Thnks in advance,
tuduvu
12 REPLIES 12
zero not zero
Eek! That's a nasty bug.
Richard
zero not zero
Yes, a nasty one.
It gets even worse (for me).
I have set up a complex calculation with a lot of gonimetric functions, and e.g. for n*PI/2 it creates a chaos-formula (extremely narrow and high spikes). So I need to filter out these arguments, and I round off the cos(angle), to force it to 0. E.g. at 14 decimals.
When n gets large, I need to set the accuracy to fewer decimals (n can get up to 10^6), e.g. to 12.
Also, I need to figure out the quadrant where, for a certain argument, the function is.
I use sign(cos(angle)), that yields only 1 and -1, never 0, as it should for the nagles mentioned.
I think I need to develop a kind of magnet function, meaning that all angle values are being left as they are, unless they are close to the problem-causing angles. Then they should snap to a better-evaluated constant, like (example 312/214).
Anyone knows an approximate for PI?
Funny: in Excel everything worked fine. It appears that one can be too accurate......
tuduvu
zero not zero
zero not zero
zero not zero
It still seems to be chopped. Maybe this will work:
As a rule of thumb, instead of writing if(x=0,1,2) one should write if(abs(x) is less than epsilon,1,2).
Robert
zero not zero
Would this function help?
Richard
zero not zero
Has anyone gotten extended-precision arithmetic to work with the symbolic processor? I'm trying to make a function that takes an extended-precision number and returns an extended-precision answer, but it doesn't seem to work. I'm attaching a worksheet that shows it working under some very special circustances for cos.
Also, I mentioned earlier that atan2 returns an answer from 0 to 2pi, actually it's -pi to pi and angle returns a value from 0 to 2pi.
Robert
zero not zero
OK, it helps if I attach the file.
Robert
zero not zero
This is what I get (apparently the trick does not work in all cases):
Xavier
zero not zero
arg(z) also returns an angle within [-pi, pi].
By the way, I've found in the past that the acos() function is also rather unreliable near zero.
Xavier
zero not zero
OK. After a night's sleep, here is what I came up with:
zero:= 0.0001 (or as small as needed)
cos.r(angle):= if(|cos(angle)| < zero, 0, cos(angle))
cos.r to be used instead of cos, when applicable (like sign / if statements)
Thanks to all of you. It was my first post in this forum, and I am happy to see the enthousiasm displayed here.
tuduvu
zero not zero
Here's a function that forces cos(x) to be zero when x is odd-integer multiple of pi/2. It is very ugly looking, but I think it works. No guarantees though!
Richard
Check out the latest
Mathcad Tip
"PTC Mathcad 15 / Prime 1-6 Update."
