zipline analysis
DickKeane
Newbie
zipline analysis
Attached mathcad 14 file analyzes zipline. It accepts three primary inputs. Horizontal span and vertical span are x&y distances between cable attach points. Max sag is variable to control tension. Forces are calculated for relaxed cable as well as for traversing load across span. Animation is provided at end to show traversing load. I'd like to disclaim all responsibility for injury or death resulting from use of this analysis.
14 REPLIES 14
zipline analysis
On 11/21/2009 11:33:24 AM, dickkeane wrote:
> I'd like to
______________________________
If you wish so or find justified, "Save as" 11 for a larger audience and check with more opinion/help/knowledge.
jmG
zipline analysis
Nothing about zspline except if either one is subjected to some other form ... and there are so many already known splines/NURBS.
public void setGZ(double[][] gz) {
//zSpline = new Cubic(Cubic.CATMULL_ROM, gz);
//zSpline = new Cubic(Cubic.BSPLINE, gz);
zSpline = new Cubic(Cubic.BEZIER, gz);
What's new or should be new ?
We have these 3 in Mathcad +++++.
jmG
zipline analysis
>splines/NURBS.
Not zspline, zipline.
Richard
zipline analysis
Found error in calc's when noticed that right saddle angle did not change polarity when traversing along cable. Corrected formula for right saddle angle. It than affected force calc's which have also been updated. Rev2 file is attached. Glad I stated my disclaimer.
zipline analysis
To make it work in Mathcad v11, you need to
initialize mtrial and
nloops. In addition, M11 doesn't like
the first range variable definition in the
animation section (has form 1,1..1)
Stuart
zipline analysis
Thanks Stuart, saving for the 11 audience.
Like usual, the project lacks a minimal abstract, no matter how it looks obvious or not. The catenary is a word but not a function in the real world of applications. The pure catenary is the "chainette" and it changes shape to a parabola in suspended bridges. In between, the function is as per the user best fit or best model. In this work sheet, an Hermite spline is concluded. It takes the shape of maybe not pure "chainette" but up to parabola (maybe not pure parabola either). From this concept and given some fixed parameters and an adjustable one, one can shape the resulting curve. Which based on the distributed load and the length will give a very plausible shape, shown by the two combined splines. I'm surprised the project does not start by a DE ? Maybe the two sagging functions could be plotted continuous ?
The animation is visually correct, except for the minor error noted in the post from the originator. Is there a more compact construct doing same ? The "Zspline" now makes sense as illustrated. OK, I toke Hermite as an example, but it could be any of the ones previously noted.
jmG
zipline analysis
I assume that the source of the calculations it's in matlab, and this file it's a direct translation from this. I don't understand why (because matlab have good root finders) authors don't like thems.
Regards. Alvaro.
zipline analysis [Zip-line]
A zip-line (also known as a flying fox, zip wire, aerial runway, aerial ropeslide, death slide or tyrolean crossing) consists of a pulley suspended on a cable mounted on an incline. It is designed to enable a user propelled by gravity to traverse from the top to the bottom of the inclined cable, usually made of stainless steel, by holding on or attaching to the freely moving pulley. Zip-lines come in many forms, most often used as a means of entertainment. They may be short and low, intended for child's play and found on some playgrounds. Longer and higher rides are often used as a means of accessing remote areas, such as a rainforest canopy. Zip-line tours are becoming popular vacation activities, found at outdoor adventure camps or upscale resorts, where they may be an element on a larger challenge or ropes course
I have enjoyed the Zip-line indoor adventure !
I guess the "zspline" would do as well as Hermite.
jmG
I just added velocity info at end of calculation. Velocity calc's made some simplified assumptions as noted in document.
>document.
Your work sheet not saved in lower version limits the audience.
jmG
This that possible to back save this to MCD format. It will be much appreciated.
I just attached file saved as Mathcad12. Enjoy.
Re: zipline analysis [Zip-line]
