Exercise 2: Blending
a.rose.thomas
2-Explorer
Hello! I am in the middle of the Solid Modeling 2 course and the second exercise asks for a blend of three composite curves. My start points aren't aligning, and the guide recommends that they do but doesn't specify how to do that. I tried going into the sketch to manually select the start point, but since it's a referenced curve that doesn't appear to work. Any ideas on how to fix this?
Hello!
I'm assuming you are referring to Exercise 3 Task 2, in which case the guide states to align start points as necessary, not that they are already aligned.  For information on how to align the start points, continue reviewing the theory slides in the training guide for more information on how to do this. More specifically, review the next page in your training guide.
In these courses, you will find the exercises before the theory. You should be able to find additional information in the theory slides and notes that follow each exercise.
Hope this helps!
John H. Walker
PTC University
Technical Curriculum Developer
Creo Parametric
Hello!
Hope this helps!
John H. Walker
PTC University
Creo Parametric
Hi John!
Yes, I did find the information on the following pages. Thanks for your prompt response!
Fantastic! Glad you were able to work through it!
John H. Walker
PTC University
Creo Parametric
