Mistake in WCFD-WORK Exercise 6
AmberWright
I do not believe that this step is correct:
The DR-101 Design Specs file is not in the Chainsaw - 220 Series Documentation folder. It is in the WCFD-WORK/Documents folder. It is also incorrect in the tutorial video.
https://learningconnector.ptc.com/tutorial/1706689375397/create-windchill-document
I also could not right-click to copy in the VM, I had to use CTRL-C.
Hi Amber!
Thanks for reporting this - you are correct, this step is not accurate, and I have updated it. The following line will replace what you have highlighted next week.
Right-click DR-101 Design Specs and select Copy
As for using right-click to copy, this was not something I could replicate in my VM so I left it as is. However, I think it makes sense to simplify this to "Copy DR-101 Design Specs." in our next maintenance update.
