Practice Models
ptc-5195574
2-Explorer
Practice Models
Is there any place where we can download the models provided for the tutorials?
There are no models that are able to be downloaded.
However, if you are referring to the exercises in Fundamentals of Solid Modeling 2 (based on your labels), then those models can be accessed in the Virtual Machine. Instructions for accessing the virtual machine should have been on the landing page where you found the training guide.
If you are referring to tutorials in general and not specific to a course, then it depends on the tutorials you are viewing. None have downloadable files, however, most of the Get Started and some of the Learn More playlists utilize a common dataset. Those playlists have a link to drawings to be able to model the components utilized in those playlists. Get Started with Creo Parametric Modeling walks through the creation of a singular part file that you can retain.
Hope this helps!
John
John H. Walker
PTC University
Technical Curriculum Developer
Creo Parametric
Hello @ptc-5195574,
It looks like you have a response to your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
