I'm having trouble finding the directory with the files for exercise 1 in them.
After launching your VM, you can find it in the default location. Open the folder "CRFD-ASBY Creo_ Fundamentals of Assembly". Then you can navigate to the sub folders and set the appropriate working directory for each exercise.
This info is found on page 16 of your student guide. I included the screenshots below and attached them.
Hope this helps!
John
