Hello!
I assume what you mean is that you don't have this folder on your own computer? Instead of using lab files on your computer, you must first launch your virtual machine (VM). It is the VM that has the lab files for you to complete the exercises. The steps for this are listed in your class day portal where you found the training guide.
Once you have launched your virtual machine, the training guide specifies the location of the files. Here is an example:
Matt
Hello!
Matt
Thank you so much!
