There is no "Submit Change Request" Task for the Front Housing Screw Clearance Change Request. Please advise. Note I can see the CR that I edited in Task 2 in Updates, just no Task to Submit it.
~patrick
FOUND IT
Previous steps included choosing "Closed" drop-down in the My Tasks! There should be a step to change that back to "Open" for those of us who are not used to using said drop-down. All good, thanks!
~patrick
Once you Edit the Change Request in Task 2 and click Submit Later it can take a few seconds for it to make it to your home page.
Have you Refreshed your Home Page? The Submit Change Request link for the Front Housing Screw Clearance Change Request should appear after you Refresh the page. Press Ctrl R.
~Claudette
Hi Claudette,
Yes, I am familiar with it taking a bit for the system to process through and get the next step showing...I refreshed and even logged out and back in. I went and re-edited the Change Request, ensuring I hit "Later", but nope. O well. I'm going to just move on.
Thanks for trying,
~patrick
FOUND IT
~patrick
You will get stuck on the next exercise.
Can you open the The Front Housing Screw Clearance Change Request and send me an image?
Thank you,
Claudette
Good Catch. I was just looking at your tables and wondering what wasn't looking right.
Glad you found it!
Claudette
