CATIA VB.Net.edit axisSystem
priyankamakke
2-Explorer
I'm trying to reverse the zip direction of an axis system in CATIA, using VB.Net.
I tried the following :
Public Const catAxisSystemAxisOppositeDirection As MECMOD.CATAxisSystemAxisType = 2
`Public Const catAxisSystemAxisOppositeDirection As MECMOD.CATAxisSystemAxisType = 2
Dim axisSystems1 = selection1.Item(1).Value
axisSystems1.Name = "Screw hole direction." & Num_hole
axisSystems1.ZAxisDirection = catAxisSystemAxisOppositeDirection
With this it occurs an error. I tried the same in the VB6 editor inside Catia and it works. In VB.Net it doesn't.
I also tried to create a new axisSystem and I wasn't successful. I don't know what to do
2 REPLIES 2
Hi priyankamakke,
I'm unclear if this is related to PTC training. You may want to ask your question to the MindMajix support staff you've linked in your question.
Apologies I cannot be of more help.
Ryan
You need to contact with the technical support service, here: https://mindmajix.com/contact
