I can't import DWG because modelling is telling me that annotation in not in metric
Please someone could tell me how to do that?
There is also a good tutorial to understand DWG/DXF import?
Many thanks in advance.
There is a setting in config.dtl drawing_units; set it to mm. This is how we did till WF5. With Creo, I believe the procedure is more through a dialog box.
