Mechanica load intervals
JonathanHodgson
Gurus,
I've run up against the limitations of my training: if I configure a contact analysis to run with multiple load intervals, how do I view results for the intermediate ones?
Thanks!
Jonathan
In your analysis definition you can select how many load intervals you
want, and you can select to keep results for each interval.
For some reason though, I can only select this for large deformation
analyses, not for contact analyses (WF4).
It would be good to ask PTC why this is. (I'm curious about their
answer).
Of course a workaround can be to create several analyses with different
loads... not ideal, but it will work.
Best regards,
Patrick Asselman
