Windchill Tip!
avalencia
6-Contributor
Windchill Tip!
Did you know that you can set the language used by Windchill independently from your browser language? For example, if you want to use Windchill in English while using German as your language default for your browser, you can simply select Language Settings from the My Settings fly-out menu.
Are you excited about this Windchill feature? Has it made your learning experience easier?
1 REPLY 1
TomU
(To:avalencia)
For those who may be struggling to find this, the Language Configuration page was added to Windchill at 11.1 F000.  Earlier versions (11.0, etc.) do not have this option.
https://support.ptc.com/help/windchill/wc111_hc/whc_en/#page/Windchill_Help_Center%2FNewandChanged_LanguageConfiuration.html%23
