I have just installed creo parametric 10.0 version. But I can't run it, beacause when I open it says that "it is impossible to run the Quality Agent" and associate this with error code 0x0600012 . Than the program automatically closes.
Hi There,
Check out this thread: Solved: Re: Could not run to quality agent error - PTC Community
Matt
Hi There,
Matt
thanks for the reply, however it doesn't solve my problem. Because I don't have an addon folder or even a filequalityagent_64.msi file.
Please help me.
I see you've marked my post above as the solution. So, did this thread help you or are you still struggling?
Matt
