Hi Jarrod,
In Mfg Setup > CL Setup you have PPRINT setting. It allows you to set what
info you want to output in CL file. One example is that you might want to
automatically output sequence name, comments and tool name every time. You
set that in this area, and save a .ppr file. For every program you just
retrieve and use that .ppr file.
This covers getting the info into the NCL file. Your post must also do
something with it. Your post can be set to output PPRINT statements to the
NC file, to the list file, or to just ignore them.
I hope this helps,
Charles
Charles Farah
Sigmaxim, Inc. www.sigmaxim.com
1895 Centre St, Suite 102, Boston, MA 02132
(Tel) 781-329-5235 877-SIGMAXIM
(Fax) 781-329-9511
