[proecad] - FEA: Pro/Mechanica versus Nastran
JonathanHodgson
11-Garnet
I can't help feeling that this has been covered before, but...
- Accuracy of results in both packages depends on the user. Both can
produce reliable numbers if the model is set up correctly.
- Mechanica has an upper size / complexity limit, due to memory.
Nastran will just keep on grinding, using bigger and bigger swap files,
no matter what (even if it takes days).
- Ease of meshing: Mechanica wins hands-down. The meshing is completely
automatic - although see the above point about accuracy, and my
footnote.
- The learning curve is shallower to begin with in Mechanica, but gets
steep as you get into complex models, or ones where you need to start
using mesh controls and the like to achieve the accuracy. Nastran takes
more learning initially, but then you're more or less set up for
everything.
- Mechanica's biggest asset is seamless integration with Pro/E. Once
you've attached loads and constraints to your model, you can alter
parameters (and even geometry) as much as you like, and just re-run the
analysis.
Other than that, Mechanica is generally quicker to use, certainly for
simple models, although for analyses with multiple load cases the
ability to edit the load deck for Nastran is nice. On occasion I've
imported IGES files into Pro/E to analyse using Mechanica, because it
seemed like the easiest way.
With either package, be aware that you really need an understanding of
FEA principles to guarantee reliable, accurate results. The biggest
risk with Mechanica is probably that it's too easy, and too automated -
users can get complacent, and trust the results without checking
carefully. Nastran is probably better for training up good users...
This should probably be on the proecae list, btw - I've cross-posted to
there, and future replies should ideally be trimmed to that list only.
HTH,
Jonathan
Jonathan covered most of the points. Some things to add:-
* You really should not need to spend any time on Mechanica meshing, set
the accuracy in the MultiPassAnalysis (i.e. P-level) or, if you have
high stress gradients change the Autogem (mesh) settings, I do not like
the default 5/175/95... settings and improve to better angles and more
elements on curves, e.g. 10/170/95...
* If you are doing assemblies, look at the ease of setting up contact.
Mechanica is OK for a limited number, but for a more automated approach
then Ansys Workbench works well
* While I would not recommend Ansys for accuracy (unless you do a lot of
work on meshing) it imports geometry with parameters, and sets up
contact etc well.
Regards
John
Folks, here are some comments (I use MECHANICA since '93 and we have
tested/used also MARC/MENTAT and NASTRAN):
* Accuracy in MECHANICA depends only a little on the user (SPA and
MPA gave much better results than NASTRAN, especially if you
investigate several load cases)
* NASTRAN and all other h-element calculation systems need about
3-times more degrees of freedom (DOF) to reach the same accuracy
as MECHANICA -> thus the calculation times are much longer
* The automatic meshing is quite good in MECHANICA; the size of
elements is limited to the accuracy of the geometry in both
systems, but due to the p-method you will get in MECHANICA even
at the smallest element edge much more DOF as with h-elements
(this is essential in calculating e.g. small rounds)
* All MECHANICA elements follow exactly the underlying geometry;
usually the h-elements are polygons -> this is one reason for the
better results with MECHANICA
* If you use e.g. 4-noded tetra elements in a conventional system
like MARC or NASTRAN the numerical failure in the displacements
can be up to more than 50 %; thus stresses will have failures of
more than 100 % (stresses are derived from the strains
(differences in displacements) and thus more critical); even if
you user quadratic elements and e.g. three element layers at thin
walls you can get a failure of 30 % in the stresses -> this also
influences strongly life predictions !
* Be aware of the fact, that one h-mesh can be very good for a given
load set, but can fully fail with others; MECHANICA can handle
this very good
* MECHANICA has no upper limit in elements and DOF; you can use the
64-bit version (e.g. we had a calculation with 19.5 Mio. DOF with
119.000 elements and 3 load sets: max. memory 13.3 GB, temporary
disc space 236 GB, 98.600 sec elapsed time, 199.000 sec CPU time
on a machine with 2 QuadCore processors and 16 GB physical memory)
* Learning is always necessary and needs much more time with the
h-method; but even than it lasts much longer to build up an
appropriate model in h-codes
* NASTRAN has also a limited number of functionalities (that's the
reason why msc.software bought MARC)
* NASTRAN and all h-code users do the same or more mistakes in
calculations than MECHANCA users; this results from the complex
possibilties and thus more unlogical settings.
With best regards
Stefan Reul
> footnote.
> everything.
> analysis.
> HTH,
> Jonathan
