Unable to Export Integrity Document via Gateway Export wizard
Dear All,
I am trying to export the Integrity Requirement Document via gateway export wizard in to MS Word.
All the steps done successfully but at the last step i.e. on export option showing an error ""The transformation of item "6286327", field "Text", failed. Cause: com.mks.gateway.tool.exception.GatewayException: File "C:\Users\pisec\AppData\Local\Temp\WordExport_0/[Content_Types].xml" does not exist.""
I tried to,
1. change the export directory
2. delete the temp files
3. checked the mapping files
Please let me know if there is any workaround on this.
If you would like to join any PTC Working Groups, please review the How to Join a Working Group post.
Be sure to always check to see the latest list of Working Groups and help innovate with PTC and your fellow community members!
If you do not see your topic, please Suggest A Working Group
