Document Search Returns error - None found
GC_9342786
2-Guest
Document search returns error regardless of what I search for. See image below.
Why ?
@GC_9342786 Thanks for reporting the issue with us. We are aware of this issue and are working on the fixing.
I will invite you for verification once this is addressed.
Sorry for the inconvenience!
Thank you!
Jenny
Pierre_M
(To:Jenny)
The problem has been fixed and search is up and running again
JB_7313929
(To:GC_9342786)
It happens to me every time I use the Search -
Sorry, something went wrong.
One or more resource files failed to load. Please try your query again.
I'm just looking for release notes for Integrity.  Is there another path to them?
@JB_7313929 Search is up and running. Can you follow below steps to diagnose and bring Search back on your end?
uBlock Origin is Blocking Properly Access to Knowl... - PTC Community
JB_7313929
(To:Jenny)
Thanks for the suggestions.  I had been using Edge, should have mentioned that.  The Search works in Chrome.
I was able to find the documentation that I needed through the Help Center link on the page https://www.ptc.com/en/support/refdoc.
The troubleshooting instructions suggest as the first step to clear the browser cache.  I won't do that because I return to the same sites repeatedly throughout the day and use the cache for that instead of the laborious Favorites.
