File transfer subsystem Error Source file not found - Permissions Issue
harpreetk
While I am trying to copy file using File transfer Subsystem Copy from local to thingworx repository , I am getting error :
"File transfer subsystem encountered an error: Source file 'sourcefile' not found"
Does anyone know what Permissions are required to setup for this as if I use Administrator login to copy. It worked fine.
Harpreet
1 REPLY 1
PaiChung
22-Sapphire I
(To:harpreetk)
I would check the application log.
usually this would need at minimum visibility permissions (since it tried to execute copy i'm guessing the user has permission to use copy) so give visibility to the user's org to that file repository
