Is the eSupport search down?
BineshKumar1
7 REPLIES 7
Hi Binesh - working for me - but I will alert the team to your post.
If you refresh, can you search?
Is anyone else seeing the same?
Best,
Toby
I did the same search as Binesh and for me is working fine.
Marco
BineshKumar1
(To:Tmetcalf)
Thanks Toby for the quick response. I had tried a couple of times refreshing the page, it did not help. I opened a new session and it did not work either. I tried again in the same session after I posted here, and it worked fine
Not sure, this could be our network. Thank again
Anytime - glad you are all set
TomU
(To:BineshKumar1)
Working for me too.
Hi Binesh Kumar
Could you please share with the exact URL that you are using when you see this issue (with all the query parameters) ?
Many thanks,
Peter.
Thanks Peter for the quick response. I will do that the next time I see this issue.
