Something is going on with the knowledge base search results where links to articles are appearing before the articles are (apparently) made publicly available. See pictures below.
Every one of these articles leads to this:
Many thanks @TomU to report this issue.
We will look into why these documents are not found and revert back to you with an update as soon as possible.
Thanks!
Romain
I'm assuming they're not publicly visible because Windchill 12.1 hasn't been released yet. Assuming that's correct, the search engine probably needs to be adjusted to not index or return results for any articles that are not publicly visible.
Hi @TomU ,
Indeed the files were not supposed to be indexed by the search engine. They will be available as soon as 12.1 is released.
Wish you the best for the end of this year.
Romain
