I'm trying to troubleshoot some issues today and it seems like most of the support articles are missing from the KB search results. I suspect maybe a search index issue, but not sure. I just know it's making it really hard to find solutions. I'm resorting to other search engines, but even those seem to be finding only a subset of what used to be there.
Simple example. This should return dozens, if not hundreds of support articles:
Hi @TomU and @DomenicLaritz ,
We identified root cause and addressed this now. It was indeed an issue with our connection to the CRM which impacted the knowledge base articles.
Thanks for highlighting this,
Peter.
I can confirm the problem described by @TomU! As of today, the KB articles are missing from the search results. ☹️
Peter.
Thanks!
