Open a Support Case Ui is broken (Edge DEV)
SOLVED
jgoncalves
Granite
I cannot open new Support Case
The UI is broken.
Tested on Chrome and Edge.
In the case of Edge, no Extensions where running at the moment.
Re: Open a Support Case Ui is broken
Hi @jgoncalves ,
Thanks for confirming. We see the same here on Edge Dev 89.0.760.0 and it does appear to be a compatibility issue with the HTML / CSS on the forms in the Support Assistant. As Microsoft mentions here, the Beta version they release every 6 weeks is more stable. Testing on Edge Beta 88.0.705.45 the issue is not reproducible any more.
With regard to our eSupport tools, testing happens on latest production versions of mainstream browsers (IE / Edge / Firefox / Chrome). Knowing that this could become an issue in a few months for us is helpful and the dev team has been made aware.
Best regards,
Peter.
12 REPLIES 12
Hi @jgoncalves ,
Thanks for reporting this issue to us. One of our production nodes had a brief outage earlier today and the symptoms you're describing look to be consistent with CSS not loading correctly.
All production nodes are currently UP, and so a hard refresh with Ctrl + F5 should restore functionality.
Please could you check and let us know if you are still seeing an issue ?
With best regards,
Peter.
Ctrl+F5 or Clearing the browser cache(from Edge menu) is not fixing the issue.
I've done more tests:
  • IE (Windows 10 20H2) is working
  • Microsoft Edge Version 87.0.664.75 (Official build) (64-bit) is working
  • Microsoft Edge (DEV) Version 89.0.760.0 (Official build) dev (64-bit) is not working
Image was captured from Edge Dev. It is my main browser. Don't know if is problem of Edge or PTC Site.
Hi @jgoncalves ,
Best regards,
Peter.
Re: Open a Support Case Ui is broken (Edge DEV)
I found the same today with Edge 88.0.705.63 (Official build) (64-bit) and with Chrome 88.0.705.63 (Official build) (64-bit) and with Internet Explorer from Windows 10 v1909.
It is impossible to raise a support request from any of those browsers.  I suppose it's one way of keeping your work volume under control...
I just tested my environment with
  • Version 88.0.705.63 (Official build) (64-bit)
  • Version 88.0.705.68 (Official build) (64-bit)
With both standard releases (no DEV/Canary/Beta) it worked just fine. ✔
Did you tried to disable all Edge extensions?
FYI, Edge Version 90.0.789.1 (Official build) dev (64-bit) continues to fail
Same issue here in both Chrome 89 and Edge 89.
I opened a case to tech support, but they referred me to this community thread.
Tags (1)
Today I tried with Edge Version 89.0.774.45 (Official build) (64-bit) and Chrome 85.0.4183.121 (Official Build) (64-bit) and both seemed to work.  At least the element that was broken the last time I tried (clicking the "Recommended Action" to start a support case after inputting the initial details) actually performed an action this time.  (I didn't subsequently continue to actually register the case, so I don't know that that part works).
I don't know whether it is me or PTC or both who has changed.  I can see that, since the last time I posted, my Edge version has increased, but my Chrome version has gone backwards, and I don't remember doing that on purpose.
Good for you @chapellane 🙂
I still have the same issue in both
Microsoft Edge Version 89.0.774.45 (Beta)
and
Chrome Version 89.0.4389.72 (Stable)
For me it is easy to use IE as a workaround, but it must be pretty embarrassing for PTC to still have this issue after Chrome 89 is release and Edge will be shortly.... oh wait, Edge 89 was actually released yesterday...
Hi @KimH ,
Thanks for sharing details and indeed, the overlay issue is reproducible on latest Chrome. With just under half of our users accessing our site with the latest Chrome we're working on addressing this asahp.
I'll share an update to this thread once I have a plan and timeline.
Best regards,
Peter.
Hi @KimH ,
Our team has addressed the issue with the case logger. Could you please check and let us know if this is working well again for you now ?
Many thanks,
Peter.
Hi @PeterCase
Yes, I can confirm that the form now looks correct in both Edge and Chrome version 89.
I did not complete the wizard to open a case though.
Thanks for fixing this 🙂
Have a great weekend
/Kim
