Using the Technical Support Search with the term 'Application (UNNAMED): running public notification type 118, mode spawn' it returns 1 result:
When I click on this result it says..
Does anyone know why CS234144 is missing? Is it a database issue or is the link incorrect?
@colenum thank you for bringing this issue to our attention. Our search team are looking into the issue. In the meantime you can find the information in this article https://www.ptc.com/en/support/article?n=CS246813
