TomU
May 2, 2017 3:20 PM UTC
TS Case Comments - No Email Notifications
Is there any way to get notified any time someone from tech support adds a comment to a case?  I automatically get notified when I add comments to a case but the same doesn't happen when tech support adds comments.  I've had cases where I've seen nothing for months only to find out later when looking through the case history that the technician kept adding comments but I was never notified.  I'm pretty sure this is not an email issue on my end since I do receive email notifications anytime I create a case or add comments myself.
Here's an example from one of my cases.  I didn't receive a single email notification for any of these:
Is there some way to change this so I always get notified of any case activity via email?
MarcoTosin
May 2, 2017 3:28 PM UTC
The same issue happened to me for some cases in the past.
I already written to the engineer assigned to my case, but nothing has changed.
Marco
Community Manager
May 4, 2017 2:02 PM UTC
Hi Tom Uminn
When you subscribe to a case you get an email notification if there is a change of:
  • Status
  • Severity
  • Escalation level
  • Case Owner
The status change is the important one for this case. If an engineer has sent a suggestion or is otherwise requiring something from you, they will set the case status, usually from either <Working> or <Information Received> to <On Hold / Awaiting Customer>.
You can configure the subscription to "All cases I have opened" if you'd like this to be your default preference.
Is this more problem of the status not being updated, as Marco mentions, or an issue with the tools ?
TomU
TomU23-Emerald IVAuthor
May 4, 2017 2:30 PM UTC
I would also like to get an email when the engineering adds a comment to a case.  I do get an email when I add a comment to a case (and clearly I already know that I was the one who added it), but I don't get an email when an engineer adds a comment to a case.  This is what I would like to change.
May 6, 2019 6:02 PM UTC
Happens to me all the time.  They are waiting on me for something and I have no idea they asked for it.
May 22, 2019 1:00 PM UTC
I completely agree.  It would be helpful to be updated when a comment from the TSE is added.  Unless you go in and look at the comments you don't know if there has been any progress.
