The Performance Advisor dashboard is not displaying any data.
Marco_Tosin
Since Thursday of last week, the Performance Advisor dashboard for Windchill and Creo has not been displaying any data (see attached images).
The problem is definitely not on the user side but on the PTC side, as there are already several open support tickets regarding this issue (see, for example, CS454950).
Can other users confirm what I have written above?
Marco
remy
(To:Marco_Tosin)
Indeed.
The data outage has been resolved.
thank you for the heads up.
10 REPLIES 10
TomU
(To:Marco_Tosin)
The entry links seem dead.  I can't get past here:
Marco_Tosin
(To:TomU)
I believe the problem you are reporting concerns browsers that use Chromium as their engine.
With Firefox, there are no problems logging in, but then there is no visible data.
Marco
TomU
(To:Marco_Tosin)
I just tried Firefox and still can't go any further.  Either I no longer have access, or something on this page is broken.  The buttons do nothing.
remy
(To:Marco_Tosin)
Hi
The issue has been indeed reported to Tech Support and we issued the article you attached to your post.
It has been raised internally and we are facing an IT situation.
Apologies for the inconvenience.
Our ops have been notified as soon as possible, they are actively working on it and the incident is being monitored by Tech Support.
If this is pressing on your end feel free to file a new case, this will weigh in the balance.
Marco_Tosin
(To:remy)
Hi Remi,
thanks for the update.
Marco
Marco_Tosin
(To:remy)
Hi @remy
data is now visible again.
Thank you.
Marco
remy
(To:Marco_Tosin)
Indeed.
TomU
(To:Marco_Tosin)
@Marco_Tosin,
This graph looks off to me.  Does yours show the same thing?  Where is the other 51%?
Marco_Tosin
(To:TomU)
@TomU
clicking on the image opens the details where the data is correct (see below image), but even for me ‘Peer Reports’ displays the same data as yours..
Marco
remy
(To:Marco_Tosin)
If you notice any discrepancy file a Performance Advisor case and we'll have a closer look.
