English Installation Guide guide for Thingworx 9.0 link in Reference Documents search is broken.
Message:
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
Link:
Other languages seems ok.
Hi @reengle & @TomazJeras.
After testing several times, I was finally able to recreate the issue. It seems to be a sporadic problem.
I am following up to engage the right team for resolution.
--Sharon
Hi @TomazJeras.
I'm not seeing an issue. Can you try clearing your browser cache or trying in a different browser to see if you still have an issue?
--Sharon
I am having the same problem. I have tried Chrome, Firefox, Edge, and Safari.
Hi @reengle @TomazJeras.
Since it was working when I tested, can you please provide some screenshots to walk me through what you are doing? Perhaps I did not fully understand the issue.
--Sharon
https://www.ptc.com/en/support
https://www.ptc.com/en/support/refdoc
https://support.ptc.com/search/Pages/results.aspx
https://www.ptc.com/en/support/refdoc/ThingWorx_Platform/9.0/Installing_ThingWorx_9_for_Windows
--Sharon
Thanks to @reengle for issue clarification.
I was unable to participate in discussion more.
I have been advised that the issue is resolved. Please let me know if you continue to experience problems.
--Sharon
