I am unable to hide one of the new panels on the support home page. See attached video. (Also attached.)
Hi @TomU ,
The underlying mechanism for this is the "Dismiss Bucket" - same culprit as this issue from around this time last year. It's a part of our code that is not particularly scalable and we usually see this stickiness when a given user has a lot of items which weren't cleared by a reaper that runs and removes dismissals of expired items.
I've gone in and manually cleared a few of your dismissed and expired items just now. Could you please check again next week and update this thread ?
Many thanks,
Peter
Hi @TomU ,
Many thanks,
Peter
The panel is hidden now, so it must have 'stuck' at some point in the past. I guess I'll have to wait until the next new announcement to test again. Thanks.
