We are currently experiencing a service disruption impacting community and support login. Our teams are working to resolve the issue.
eSupport Portal Switching Languages
TomU
Something is causing the eSupport portal to unexpectedly switch from English to Chinese.  It's definitely tied to cookies, but I can't figure out what is causing it.  I'm using Firefox as my primary web browser with Windows 10.  I use the support site extensively almost every day and suddenly out of the blue it will switch the language to Chinese.  I do not have Chinese configured as a language in my web browser nor is it an installed language in Windows.  Every time this happens I delete all cookies for ptc.com and that resolves the issue for the time being, but not permanently.  Not sure how to troubleshoot this, but I really wish it would stop happening.
Not sure if it matters, but I use https://help.ptc.com frequently because it's easy to remember.  I wonder if something is messed up with the automatic redirection from there to https://www.ptc.com/en/support/help, or most recently https://www.ptc.com/cn/support/help.
Here are the last three tabs I opened.  Notice the transition:
Jean-Christophe
(To:TomU)
Hi @TomU ,
We had an issue where accessing some localized URLs woud update your language preference (stored on our server), which would then set the cookie on your browser. These have been fixed a few months ago, so you should hopefully no longer see this behavior : accessing "https://help.ptc.com" should redirect you to "https://www.ptc.com/en/support/help" if your language preference is set to English, "https://www.ptc.com/ja/support/help" if it is set to Japanese, etc.
I hope this helps.
TomU
(To:TomU)
Here's the cookie that is getting incorrectly set.  If I delete this one cooking the site returns to English.
Jean-Christophe
(To:TomU)
Hi @TomU ,
I hope this helps.
TomU
(To:Jean-Christophe)
Thanks!
