Hello Community,
What does the cummunity think of a IDF 4.0 support in Creo Parametric 5.x?
Regards Thomas
Sorry wrong community...
Thomas,
have you opened this idea also under Creo section?
In affirmative case, can you please give me the link so I can vote up?
Hi Tosin,
Yes I thought I had, but I will create one and post the Link here.
Thank's Thomas
Here is the link to the Creo Parametric Idea:
https://community.ptc.com/t5/Creo-Parametric-Ideas/Creo-Parametric-IDF-IDF-4-0-support/idi-p/546786
