When working in a Solidworks session, using the Windchill Workgroup Manager for Solidworks package, there is not way to insert a Creo model, into the SW session. This capability is available outside of the workgroup manager, when performing the same function from a local disk.
It would be nice, for customers that have the WGM for SW, and using PDMLink as their main PLM took, to be able to insert the Creo model directly from the SW file explorer vs having to save those models to disk, either naively or as STEP model, and then inserting into their SW assemblies.
