Meaningful / speaking file names should be used for the documentation.
Current situation (example): 5C0593F1C8D041FF8378FA830B724AE0.pdf ((11.1 M020) Windchill Software Matrices)
Recommended: Windchill_Software_Matrices_11.1_M020_2020-04-09.pdf
So it is possible to store this documents hierarchical in the personal file-system (and find them again).
