2021-05-14 Friday Humor (A good excuse.....)
Dale_Rosema
Hope you have a blessed weekend. The weather here is suppose to be great for a spring weekend. Sunny, mid 60's and a slight breeze off the big lake. Enjoy. Hug the ones you love.
Engineer's Diet
We all know that it takes 1 calorie to heat 1 gram of water 1 degree celsius. Translated into meaningful terms, this means that if you eat a very cold dessert (generally consisting of water in large part), the natural processes which raise the consumed dessert to body temperature during the digestive cycle literally sucks the calories out of the only available source, your body fat. For example, a dessert served and eaten near 0 degrees C (32.2 deg.F) will in a short time be raised to the normal body temperature of 37 degrees C (98.6 deg. F). For each gram of dessert eaten, that process takes approximately 37 calories as stated above. The average dessert portion is 6 oz, or 168 grams. Therefore, by operation of thermodynamic law, 6,216 calories (1 cal./gm/deg. x 37 deg. x 168 gms) are extracted from body fat as the dessert's temperature is normalized. Allowing for the 1,200 latent calories in the dessert, the net calorie loss is approximately 5,000 calories. Obviously, the more cold dessert you eat, the better off you are and the faster you will lose weight, if that is your goal.
This process works equally well when drinking very cold beer in frosted glasses. Each ounce of beer contains 16 latent calories, but extracts 1,036 calories (6,216 cal. per 6 oz. portion) in the temperature normalizing process. Thus the net calorie loss per ounce of beer is 1,020 calories. It doesn't take a rocket scientist to calculate that 12,240 calories (12oz. x 1,020 cal./oz.) are extracted from the body in the process of drinking a can of beer. Frozen desserts, e.g., ice cream, are even more beneficial, since it takes 83 cal./gm to melt them (i.e., raise them to 0 deg. C) and an additional 37 cal./gm to further raise them to body temperature. The results here are really remarkable, and it beats running hands down.
Unfortunately, for those who eat pizza as an excuse to drink beer, pizza (loaded with latent calories and served above body temperature) induces an opposite effect. But, thankfully, as the astute reader should have already reasoned, the obvious solution is to drink a lot of beer with pizza, and follow up immediately with large bowls of ice cream.
We should all be thin very soon if we adhere religiously to this cold pizza, cold beer, and ice cream diet.
9 REPLIES 9
kdirth
20-Turquoise
(To:Dale_Rosema)
Sounds good to me.
Just don't listen to the dieticians who will try to tell you that a food calorie is 1000 scientific calories and everything will be OK. 😉
StephenW
(To:Dale_Rosema)
I'm all in. Finally science has done something that makes my life enjoyable instead of telling me how badly I am damaging my body!
Following the logic stated, I should be a real fashion figure, but I'm not.
Maybe I need to drink much, much colder drinks. 😁
Marco
olivierlp
Community Manager
(To:Dale_Rosema)
I feel enlightened! I cant wait to go grocery shopping!
Olivier
Dale_Rosema
(To:Dale_Rosema)
How did everyone do on their diet this weekend.     🙂 🙂
TomU
(To:Dale_Rosema)
I think something's wrong with the math.  I keep eating ice cream and I'm not losing any weight...  🤔
Dale_Rosema
(To:TomU)
My son works at Hudsonville Ice Cream - we currently have over 20 containers of ice cream in our freezer. Almost time to by another freezer.....   🙂
TomU
(To:Dale_Rosema)
I work across the street.  That's quite the addition they're putting on!
StephenW
(To:Dale_Rosema)
I may be negative weight now!!
