PTC Community Monthly Stand-Out December 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of December..
Top December 2023 Community Engagers:
@HelesicPetr @avillanueva @tbraxton @Werner_E @LucMeekes @MartinHanak @terryhendicott @Hari_Vara @VladimirN @Chris3 @StephenW @BenLoosli @kdirth @jbailey @ttokoro @pausob @XDN @aputman @KenFarley @AL_10888052 @aletenti @nmutter @Michael @nmilleson @SweetPeasHub @FriedhelmK @MSALAS @Sathishkumar_C
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for December 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: danders238 asked about How to control multi line text of an Annotation Note using Family Table Instance value?. Solution was provided by pausob
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-to-control-multi-line-text-of-an-Annotation-Note-using/m-p/922665#M132872
2. Creo: MZ_9604297 received an accepted solution from pausob for topic Tolerance text height the same as dimension text height in 3D annotation
https://community.ptc.com/t5/3D-Part-Assembly-Design/Tolerance-text-height-the-same-as-dimension-text-height-in-3D/m-p/920819#M132747
3. Creo: Thank you  for providing an accepted solution for ashaik on this topic Creo 10.0.2 Crashes while opening large Assembly.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Creo-10-0-2-Crashes-while-opening-large-Assembly/m-p/921495#M132767
4. Creo: AB_10071442 needed help with this topic - How can I bring back my default datum planes when creating a new combination state? and  offered him an accepted solution.
https://community.ptc.com/t5/3D-Part-Assembly-Design/How-can-I-bring-back-my-default-datum-planes-when-creating-a-new/m-p/920307#M132723
5. Creo: A question about Creo Animation real time duration was posted by gfraulini and an Accepted Solution was provided by Chris3
https://community.ptc.com/t5/Analysis/Creao-Animation-real-time-duration/m-p/920054#M11823
6. ThingWorx: Sathishkumar_C gave an Accepted Solution to VR_10133499 for the topic All Drop downs showing same value.
https://community.ptc.com/t5/ThingWorx-Developers/All-Drop-downs-showing-same-value/m-p/920418#M64958
7. ThingWorx: The topic What is the optimal number of channels on KepServerEx?
posted by JK_10565232 received an accepted solution provided by cmorehead.
https://community.ptc.com/t5/Kepware/What-is-the-optimal-number-of-channels-on-KepServerEx/m-p/919591#M1635
8. ThingWorx: Rocko provided a speedy response and Accepted Solution to the inquiry by DJ_9847497 about Grid Configuration.
https://community.ptc.com/t5/ThingWorx-Developers/Grid-Configuration/m-p/917206#M64746
9. ThingWorx: oskarberntorp had an issue with Display iframe in mashup and TonyZhang provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Display-iframe-in-mashup/m-p/918772#M64852
10. ThingWorx: ZbigniewK posted the topic Permisions for users and groups
and received an Accepted Solution from Rocko.
https://community.ptc.com/t5/ThingWorx-Developers/Permisions-for-users-and-groups/m-p/919085#M64878
11. Vuforia: AlexK shared a post about Data Grid Widget without Thingworx.
Thank you whity for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Data-Grid-Widget-without-Thingworx/m-p/919615#M12209
12. Vuforia: WZ_10636454 posted the topic How to change the style of waypoints labels? and received an Accepted Solution from ClayHelberg.
13. Windchill: OnurNalbantgl posted the topic Report by Transition or Mail robot
and received an Accepted Solution by
https://community.ptc.com/t5/Windchill/Report-by-Transition-or-Mail-robot/m-p/917319#M76558
14. Windchill: Brndn4 asked about the Creo Parametric Parameter -> Windchill Attribute Mapping - Legacy Value Population and mmeadows-3 provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/Creo-Parametric-Parameter-gt-Windchill-Attribute-Mapping-Legacy/m-p/920582#M76966
15. Windhill: Dennis_V_NL asked about Windchill search with an Acccepted Solution from
https://community.ptc.com/t5/Windchill/Windchill-search/m-p/920293#M76946
16. Windchill: PK_9881178 asked about How to run jsp file on windchill url without creating an action on windows OS and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/How-to-run-jsp-file-on-windchill-url-without-creating-an-action/m-p/920640#M76973
17. Mathcad: AL_10888052 needed help with Varying cross section along length of span (x) via Programming in MathCAD solution needed! and  provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Varying-cross-section-along-length-of-span-x-via-Programming-in/m-p/917493#M209696
18. Mathcad: justhumm needed with Simple beam analysis - moment equation...?
and  helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/Simple-beam-analysis-moment-equation/m-p/920727#M209874
19. Mathcad: Cornel asked about Conversion between DECimal, BINary, HEXAdecimal and OCTal numbers...? and  provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/Conversion-between-DECimal-BINary-HEXAdecimal-and-OCTal-numbers/m-p/920195#M209830
20. Mathcad: Cornel  asked about Stem Plot: No "error" returned but red graph. Why? with an Acccepted Solution from ttokoro.
https://community.ptc.com/t5/Mathcad/Stem-Plot-No-quot-error-quot-returned-but-red-graph-Why/m-p/920203#M209832
Andra
0 REPLIES 0
