PTC Community Monthly Stand-Out November 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of November..
Top November 2023 Community Engagers:
@HelesicPetr @Werner_E @avillanueva @tbraxton @MartinHanak @Velkumar @Chris3 @kdirth @StephenW @ttokoro @terryhendicott @LucMeekes @jbailey @BenLoosli @Dale_Rosema @rleir @nmutter @RPN @VladimirN @YaroslavSin @KenFarley @Arun_C @Rayon_11 @SweetPeasHub
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for November 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: nsgoldberg  asked about Geometric Tolerance Issues. Solution was provided by Chris3
https://community.ptc.com/t5/3D-Part-Assembly-Design/Geometric-Tolerance-Issues/m-p/911452#M131983
2. Creo: MW_10709014 received an accepted solution from kdirth for topic Objects are not visible in the drawing.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Objects-are-not-visible-in-the-drawing/m-p/914786#M132279
3. Creo: Thank you Tdaugherty  for providing an accepted solution for DS_10868229 on this topic Mirror function not working properly Creo Parametric 8.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Mirror-function-not-working-properly-Creo-Parametric-8/m-p/914257#M132236
4. Creo: DJHyp needed help with this topic - Manual Modeling of Stiff Bolts in Soft Channels and skunks offered him an accepted solution.
https://community.ptc.com/t5/Analysis/Manual-Modeling-of-Stiff-Bolts-in-Soft-Channels/m-p/912151#M11720
5. Creo: A question about Self-weight in CREO Simulate was posted by luiz.hnm and an Accepted Solution was provided by SweetPeasHub. Thank you @skunks for your contributions as well!
https://community.ptc.com/t5/Analysis/Self-weight-in-CREO-Simulate/m-p/912579#M11731
6. ThingWorx: AS_10340651 gave an Accepted Solution to P_10844769 for the topic On mashup load, how to all select values from dropdown?
https://community.ptc.com/t5/ThingWorx-Developers/On-mashup-load-how-to-all-select-values-from-dropdown/m-p/914663#M64629
7. ThingWorx: The topic Unable To Convert From org.mozilla.javascript.UniqueTag to INFOTABLE - See Script Error Log for more posted by LY_10691079 received an accepted solution provided by Arun_C
https://community.ptc.com/t5/ThingWorx-Developers/Unable-To-Convert-From-org-mozilla-javascript-UniqueTag-to/m-p/915393#M64673
8. ThingWorx: Velkumar provided a speedy response and Accepted Solution to the inquiry by Rayon_11 about How selected section of pie chart widget will work in thingworx 8.5 version.
https://community.ptc.com/t5/ThingWorx-Developers/How-selected-section-of-pie-chart-widget-will-work-in-thingworx/m-p/914510#M64613
9. ThingWorx: EK_10370207 had an issue with Grid Advance display & img? HTML and ShirishMorkhade provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Grid-Advance-display-amp-img-HTML/m-p/913331#M64553
10. ThingWorx: Rayon_11 posted the topic How to apply aggregate functions on grid data and received an Accepted Solution from Arun_C.
https://community.ptc.com/t5/ThingWorx-Developers/How-to-apply-aggregate-functions-on-grid-data/m-p/912464#M64497
11. Vuforia: LX_10186967 shared a post about Can't delete project in vuforia View.
Thank you mwodarz_INNEO for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Can-t-delete-project-in-vuforia-View/m-p/914488#M12131
12. Vuforia: LX_10186967 posted the topic Vuforia Studio View Navigation Menu and received an Accepted Solution from ClayHelberg.
13. Windchill: RFS posted the topic For a Windchill object, can the Members area be restricted from editing?  and received an Accepted Solution by .
https://community.ptc.com/t5/Windchill/For-a-Windchill-object-can-the-Members-area-be-restricted-from/m-p/836712#M68977
14. Windchill: HO_10736653 asked about the how to get object's creator in DataUtility and provided the Accepted Solution.
https://community.ptc.com/t5/Windchill/how-to-get-object-s-creator-in-DataUtility/m-p/915573#M76355
15. Windhill: MB_10389467 asked about Windchill 12.1 Upgrade - Database Import
with an Acccepted Solution from DaveBfoot. Thank you  for your contribution!
https://community.ptc.com/t5/Windchill/Windchill-12-1-Upgrade-Database-Import/m-p/915719#M76383
16. Windchill: Sandy7 asked about My task table is filled with many resolved tasks and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/My-task-table-is-filled-with-many-resolved-tasks/m-p/915667#M76373
17. Mathcad: QA_10868748 needed help with How could I get a value from a matrix with js? and  provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/How-could-I-get-a-value-from-a-matrix-with-js/m-p/914358#M209506
18. Mathcad: JE_5076959 needed with MATRIX CONFUSION (Beginner to matrices)
and  helped with an Accepted Solution.
https://community.ptc.com/t5/Mathcad/MATRIX-CONFUSION-Beginner-to-matrices/m-p/913289#M209448
19. Mathcad: relayman357 asked about odd result when plotting offset circle and  provided the Accepted Solution.
https://community.ptc.com/t5/Mathcad/odd-result-when-plotting-offset-circle/m-p/913394#M209464
20. Mathcad: AD_10780197 asked about ODE solver steps with an Acccepted Solution from ttokoro. Thank you  for your contribution!
https://community.ptc.com/t5/Mathcad/ODE-solver-steps/m-p/912769#M209414
Andra
0 REPLIES 0
